1 - 11 of 11 Posts
1. AEM doesn't make anything application specific for the B13 or B14.
2. If you're going standalone you might as well get something for the ignition. IMHO it isn't worth it on our cars if you keep your distributor. Coil on plugs or a coil packs are the cats pajamas.
fabricator
it's not that bad. All you need to do is take the disc from the distributor and block off groups of slots, or cut a new one with fewer slots. Or just run a crank trigger wheel and sensor. I think it would be cleaner to use the stock pickup though; it is enclosed, accurate, and already attached to the motor :)
andris
1 - 11 of 11 Posts
