El Chingon
Hey everyone! Just wonderin if anyone with an OBD II equiped car (internal coil) has an aftermarket ignition. I need to wire the ignition onto my '98 SE, but I don't have a FSM, or any wiring diagrams for that matter, that could help me. Anyone out there with one that could drop me a line...?? TIA!!
David
'98 Super Black SE w/stuff
I have the diagram on how to install an MSD 6A onto the B14 at my house. I will give it to you this weekend. Call me 480-922-7303 x205 wk or 480-545-8770 hm. Does Joser still need the motor mounts? Are you cruising over to the Pavillions this weekend?
Louis Anaya 1992 Sentra SE-R
349.6 hp & 301.4 ft/lb @ 19 psi, 13.6 @ 111 mph(Street Tires),12.0 @ 118.77 mph(Slicks), Bluebird SR20DET w/ GTiR Pistons,T3/T04E,Deltagate Wastegate (7-9 PSI) FMAX Manifold, RevHard FMIC, JWT S3 Cams, JWT Ported & Polished Head, 1996 200SX SE-R Welded & Cyro Treated Tranny, ACT Xtreme P/PL & 6 Puck Disc, Cobra MAF, JWT ECU w/ 4 Bar Fuel Program, MSD 50lb/hr Injectors, JWT Fuel Rail, 300ZXTT Fuel Pump, AeroMotive Adjustable Fuel Pressure Regulator, Greddy Type "R" BOV, Greddy Profec B, Greddy Boost & EGT Guages, UR 4 Pulley Kit, Powerslot Rotors, Axxis MM Brake Pads, ES Motor Mounts, Topspeed Short Shifter, Momo Cobra Shift Knob, KYB AGX Struts, GC Coilovers (350F/600R)& 17x7 White Tenzo Shu-4's w/ Sumitomo 205/40/ZR17 Tires (Street), 13x7.5 White Lenso VPD's w/ Mickey Thompson 24.5x8x13 Slicks(Drag)
El Chingon
Bad Ass!! Cool man! Yea, he still needs the mounts. Yea, I'll be cruising out with everyone. You going? Did you figure anything out on the problem with the car? Did you talk to Clark or Jim about it yet?
David
I am sending the ECU out today again. I spoke with Mike Kojima for about an hour last night and I talked to Clark yesterday also. The code 21 is nothing I have to worry about and isn't even linked to the 6000 rpm problem from what Clark told me. Clark is going to install a new cable and also a new NO2 board for the Drag Launch Program. Hopefully it will solve the proble. I swapped out the MSD 6A for a new one & I still had the same problem. My car is down, since I am sending the ecu out today. If you want, I will cruise with you guys if you pick me up. Let me know. I can give Joser the mounts this weekend. I will also get you that diagram.
El Chingon
Damn, that thing is just ****in weird!! LOL! I kept thinking about at and looking at the wiring diagrams, but nothing! I just couldn't think of anything that could make it do that. Yea, I'll pick you up. I'll throw a message out to the AZ list to see who's going and what time everyone's heading out.
David
