Since Harris won't do this anymore, I will:
Search! You'll find out why your combo won't work.
I have searched for weeks and found very useful information, I even found the insturctions on JWT site useful, if you are running the internal coil. I know my setup will work because several other people are running it. It kinda pisses me off that you will just post "SEARCH!" without knowing what someone has done. I know Harris retired the search nazi title and I don't think you should be his self-appointed successor.Slartibartfast said:Since Harris won't do this anymore, I will:
I didn't break the internal connection to run the external trigger wire because of a post that I SEARCHED through I saw that Jay Hass said you didn't have to run the external trigger wire if you are hooking up an external coil. I do have all the settings on the MSD set right and when I test for spark like the directions said, I get spark. Maybe my trigger wire isn't working then.iczer200sx said:just for reference, i drilled the cap to insert the tower adapter, but didn't have to break the connection inside the cap. did you modify the distributor, in terms of breaking one of the internal connections and soldering the trigger wire (white) there? hopefully you broke the right one. also, make sure it's set to 0 (4 cyl). which instructions are you referring to?
As if anyone voted Harris into the position...He learned everything he knows about Search Nazi from me. I welcomed the vacation while he fulfilled that duty. Since he's retired, well, SOMEONE has to do it.and I don't think you should be [Harris'] self-appointed successor.
Seems to me you didn't mention having searched. So, I assume you're like the other guys who move their lips/fingers without first engaging their brains.It kinda pisses me off that you will just post "SEARCH!" without knowing what someone has done.
do you ever have anything nice to say? he has 5xx some post dont you think he knows how to searchSlartibartfast said:As if anyone voted Harris into the position...He learned everything he knows about Search Nazi from me. I welcomed the vacation while he fulfilled that duty. Since he's retired, well, SOMEONE has to do it.
Summit sells them all day long.BORNGEARHEAD said:I'll buy your Digital 6.![]()
I'm pretty much like TV news: only the bad stuff gets a mention.do you ever have anything nice to say?
Post count doesn't really mean much other than he posts a lot. I've seen seen some very experienced folks here unthinkingly throw out questions on subjects that have been beaten so far into the ground you get oil. I'm not going to assume they search unless they say so.he has 5xx some post dont you think he knows how to search
better late then neverJackson Diamond said:You had to run an external trigger. If i would have saw post earlier i could have told you that.
Yeah sorry[email protected]$t9d7 said:better late then never![]()
