1 - 10 of 10 Posts
JordanWhiteMusic.com
Depends.
For regular driving, usually 1 and 2 or occasionaly 2 and 3. There isn't all that much difference actually.
For the drag strip 1 and 8. Autocross 3 and 6/7. For road courses, of course 4 and 8.
-Nuke the bastards-
Stormy
'98 SE(R) w/ HS CAI, HS G3 Header, Custom 2.25" Exhaust, JWT S4 Cams, UR Pulleys, KYB AGX's, Eibach Spings, Courtesy F&R STB's, ES Mounts, ES control arm bushings & shifter bushing (NI), Brembo X-Drilled Rotors w/ Axxis MM Pads, 205/50 Pirelli P700z's
www.WhiteLineRacing.com
i dont have any on the front yet but i run 8 on the rear all the time i love having my suspention that stiff makes it over stear alittle on wet roads and apex breaking but i like that little bit of overstear make my drivng skills alittle better.
David
I'm a bit suprised. Except for Madmoney those are "soft" settings. For me 2F / 4R. I'm thinking of 5 or 6 in the rear.
93 SE-R JWT S3 Cams, JWT ECU, JWT Pop-Charger, HS Header,RT Cat, HKS exhaust, Hypercoils, KYB-AGX, ST Sways, N-Tech Brace, Stillen STB, SMC SS.
<font face="Verdana, Arial" size="2">Originally posted by Storm88000:
That is super-damped for the street.
Yet another advantage to living in sunny Florida.
No frost heaved roads. Seriously 2F / 4R is close to sock dampening. It's my springs that make it a bit firm.
newbie
<font face="Verdana, Arial" size="2">Originally posted by Pretty White:
What settings are you guys using on the AGX's. I am putting mine in tomorrow.</font>
I actually find 4 in the front to be quite nice on rough roads. It is stiff as hell though to push down when you are checking the shock stiffness. When I put it on 1 or 2 it is bouncy but firm.
Hell, maybe it is because they are new but 2 in the rear is friggin stiff. Imagine 8? Geesh!
1 - 10 of 10 Posts
