OK. I just installed the AGX/Pro-kits. I feel all manly from compressing the springs way more times than I should have needed to.
Ben, I read through your thread in the archives about your alignment but didn't see the answer I wanted. My front is fine (0 toe, acceptable camber) but the rear camber is at 0.31 (both sides). So my thrust angle is still fine. But will that toe cause any wear problems? Handling? NOTE: I installed a ST rear swayt bar with the stock suspension.
I'm gonna go play with the shock settings and handling this afternoon
