Wow, um, no. You needed to use a timing light to do this. Just turning it a bunch one way can either make you lose a bunch of power or cause detonation from too much advance. Don't drive the car at all. To make it safe to drive to get/borrow a timing light, loosen the two distributor bolts and twist it so its right in the middle and tighten it back down. In *MOST* cases, this should be somewhere in the realm of acceptable timing. You should read the instructions on se-r.net. If you did, you didn't read them very carefully. You probably shouldn't just do stuff like this without knowing exactly what you're doing; there is potential to cause serious problems.
wait.... i just re-read your post. Did you turn the whole distributor, or did you actually open it and turn the rotor? if you did the latter, DO NOT DRIVE THE CAR until you put it back where it was. the rotor is in a very specific location. If you don't have access to a timing light, you should leave this to a professional.
EDIT>>
Eric, what are you talking about? that is NOT something you should ever do!
Andris
[This message has been edited by andris (edited 09-27-2001).]
