What "Hacking" are you talking about? You classify pulling a few pins out of the ECU and re-pinning , "Hacking"? That is hardly "Hacking"! The 97 ECU upgrade to a 98-01 SR20DE isn't too large of a job. As long as you have some sort of mechanical skills, you should be able to do it. If you do not wish to try re-pinning the ECU, I suggest waiting. You will have a much safer, dependable, and reliable turbo system if you have the right engine control unit. You could aslo go the Stand Alone System route. Only problem is, you will need to do extensive dyno tuning.
Louis Anaya 1992 Sentra SE-R
13.6 @ 111 mph(Street Tires),12.7 @ 112 mph(Slicks), Bluebird SR20DET w/ GTiR Pistons,T3/T04E,Deltagate Wastegate (9 PSI) FMAX Manifold, RevHard FMIC, JWT S3 Cams, JWT Ported & Polished Head, 1996 200SX SE-R Welded & Cyro Treated Tranny, ACT Xtreme P/PL & 6 Puck Disc, Cobra MAF, JWT ECU w/ 4 Bar Fuel Program, MSD 50lb/hr Injectors, JWT Fuel Rail, 300ZXTT Fuel Pump, AeroMotive Adjustable Fuel Pressure Regulator, Greddy Type "R" BOV, Greddy Profec B, Greddy Boost & EGT Guages, UR 4 Pulley Kit, Powerslot Rotors, Axxis MM Brake Pads, ES Motor Mounts, Topspeed Short Shifter, Momo Cobra Shift Knob, KYB AGX Struts, GC Coilovers (350F/600R)& 17x7 White Tenzo Shu-4's w/ Kuhmo 205/40/ZR17 Tires
[This message has been edited by APEXSER (edited 02-27-2001).]
