i have a 93 classic and recently noticed a rattling/buzzing emitting from around the front left area of the car... possibly from under the dash or from the LR side mirrors...
it comes and goes ... probably depending on the road surfaces.
normally i'd just turn my stereo up to drown the noise away but my stereo's broke =/
I had this same rattle. I hate rattles! Mine turnd out to be a broken left thrust washer. You will have to remove the front shock-spring assembly to fix it, if this is the source of your rattle..
93 SE-R JWT S3 Cams, JWT ECU, JWT Pop-Charger, HS Header,RT Cat, HKS exhaust, Hypercoils, KYB-AGX, ST Sways, N-Tech Brace, Stillen STB, SMC SS.
_______
When the speedo cable needs replacing, it develops a very annoying buzzing sound.
Check and see if your speedo needle bounces around a bit as you drive, and that's your problem right there, easy fix.
