1 - 11 of 11 Posts
FWD PWNAGE IS HERE!
I ran into this the other day on atpturbo.com and it looks pretty damn cool. Great way to hookup some ss braided water lines to your turbo...
Banjo Fitting Kit for coolant lines
I noticed it says works only with 14mm banjo bolts and I remember mine on my t28 being more like a 17mm bolt or something? Can anyone confirm whether this will work on either a t25 or t28?
Tired!
FWD PWNAGE IS HERE!
Hmm I am just aiming for water feed and return though. After searching for so long and not finding anything taht seems like itll work that atpturbo setup seems mighty tempting lol. Considering the price of the an fittings that isn't a bad price either. Just wondering if the bolt holes on the water holes on my t28 are 14mm or not. What do you think?
Do you have pics of your ride with those subzeros either?
Yep, they fit our T28. :)
Matt
Tired!
My website is www.fatrabbitclub.com for pics of the car.
Thanks to Sirnixalot for the following info, but maybe you can use it.
for those of you who require new oil and water lines for any fwd/awd SR20DET you will need to know this
(all part numbers for summitracing.com)
Oil supply line
12mmx1.25 to -3AN union adapter-----GDR-30506M12P
Pre terminated -3AN hose with one 90* end (change the last 2 digits for length in inches....for a stock location turbo you should only need 12")----EAR-63011712
-3 AN To 7/16 -24IF union adapter---- EAR-591932
Water supply (the small tube coming off the thermostat housing, retaining the bit of rubber hose)
1/4" hose barb to 1/8" NPT union adapter----EAR-984004
1/8" NPT female coupler----RUS-661440
1/8" NPT to -6AN union adapter----EAR-981662
-6AN straight hose end----EAR-800106
-6AN hose(this is for a 3 foot section which will cover both the supply and return)----EAR-403006
-6AN 90* hose end----EAR-809006
-6AN to 14mm x 1.5 union adapter----EAR-991954
Water return
-6AN hose(see above)----EAR-403006
6AN 45* hose end----EAR-804506
HKS GT28/30 series Oil Return line (modify as aplicable to adapt your T-25/28, T-3/T04 to the -10AN line)
HKS oil drain fitting ----5441-164287
-10AN weld fitting----EAR-967110
-10AN hose end----EAR-300110
3 feet of -10AN hose----EAR-403010
10AN to 1/2" NPT union adapter----EAR-981610
1/2" NPT female coupler----EAR-991004
1/2" BSPT to 1/2" NPT union adapter----4888K194 (www.mcmaster.com part number)
1 - 11 of 11 Posts
