I looked on jgycustoms and they said this:
"u13 bluebird sr20det motor. newer motor then u12, but no top mount intercooler. always in our warehouse. $1700"
if it has no top mount intercooler, isnt that bad
Undecided
Wow, you really didn't pay attention to your first post on this subject did you? Using the Top mount intercooler is a waste of time. You can front mount a intercooler for 350$ including the intercooler. A U13 does not come with a I/C because it is a front mounted Stock setup and when engines get pulled and shipped here they don't send the I/C. The U13 is newer and theoretically
better than a U12 because its newer and probably has lower miles.
EDIT: Also, a stock top mount I/C will not fit under the hood of a 200sx.
MauiBlueGride said:
Chris - it will at least the bluebird will, I think the GTi-R even will...
I installed a bluebird into a 200sx with top mount before with 0 problems....
Chris
will a gti-r fit in a 1995 sentra, yeah I want a front mount i/c but just dont know how much its gonna costs me, is the u13 better performance wise??? anyone know the specs
Undecided
Ok you have these two motors sitting next to eachother.
U12 APproximately 75K miles
U13 Approximately 40K miles
Which do you choose?
You may be getting an I/C with the U12 but you'll throw it away in a couple months when you want to front mount it. You can get a bigger I/C for about 100$ if you get like a Starion or soemthing similar off ebay. Then look at the Floridasr20.com site on how to make your own I/C piping. Its so easy its retarded not to do it yourself.
