1 - 11 of 11 Posts
Charlie Brown look alike
Here is everything I believe I have left after selling the chassis. If my prices seem to high, please LMK and counter offer. I have been out of the game for a bit.
-UK SR20DE 10:1 bottom end (verified), SR20VE head, SR16VE cams, all oil lines needed/already ran, VE oil pump, VE oil pump spacer, SR20VE metal
head gasket, Ishihara-Johnson metal crank scrapper, new NGK spark plugs, Thermoblock spacers, Nismo FPR with gauge, all hardware is either stainless steel
or black anodized allen head screws/bolts. Mint black VE valve cover. Motor is already put together. You just need to install it.
-Two extra VE valve covers you could use to powder coat, etc. after you clean them up
-UR Pullies - 2 piece Silver set; Crank and water pump
-Clutchmasters 10lb. Flywheel - Great condition.
-Used ACT HDSS clutch setup - Has pressure plate, clutch disc and alignment tool. Used for about 15K miles prior to me getting.
-'97 200sx Se-r tranny - in good condition from my understanding; has brand new throwout bearing and polished shaft. It's buttery smooth.
All of the above is already put together. Package deal - $1650 for everything
-(4) 15" (15x6.5) Rota C8 Steel Grey rims with 205/50R15 Bridgestone S03's on them (used for track, good for about 2 more events) - Asking $450 OBO
-(4) 15" (15x7) mint Rota C8 polished black rims polished lip; these rims were a limited edition run - Asking $450 OBO
-KYB AGX w/ GC coilovers @ 375/300 front and rear respectively. They have about 15K miles on them - Asking $300 OBO
-Stillen front strut tie bar - Asking $75
-Active Tuning Rear strut tie bar - Asking $75
-Progress front and rear sway bars - Asking $200
-Whiteline 4 point LCA brace - Asking $75
-Motivational Engineering solid rear pillow ball mounts - Asking $150 OBO
-4x Koni bump stops - Asking $45
-GC Castor/Camber mounting plates; in fantastic shape - Asking $225
-Prothane 4-piece motor mounts - Will be pressed in when you get them. - Asking $75 as the mounts will come ready to install
-3" VRS Stainless Steel exhaust - catback all the way to a muffler and tip. Brand new. - Asking $300 OBO
-PR CAI - worked on my old highport, but believe it's a lowport design as it was tight on the highport. Comes with all hoses, clamps and filter (if I remember correctly) - Asking $75 OBO
-AEBS 4-to-1 Header - really good condition. slight denting on the bottom, but very minor. fully painted with Silver POR15. I noticed there area few spots that have gotten marked up when moving it around. I'll touch that up and give you the left over POR15 paint. Asking $200
-NX Radiator - really good condition - Asking $50
-Random Thoughts Power Steering eliminator adjuster. This is a very rare item. - Asking $150
-OEM passenger side axle - excellent condition - Asking $50
-Lotek B13 3-gauge pillar pod brand new in bag; light gray - Asking $45
-SMC BABK - 11.75" 4-piston Wilwood Aluminium calipers, 2 piece directional vane rotor, stainless steel brake lines for teh front calipers - Asking $450 OBO
-'92 Maxima SE Rear brake setup; fully loaded - this is meant to go with the above brake. You just need an Altima M/C to complete the setup. I have one but it went with the
just curious if these are still available?
Don't call it a comeback
YOur PMs are full...I am very interested in that intake. Pm me please
Ian
PM sent
PM Sent...again.
1 - 11 of 11 Posts
