OK so I have a 95 200sx se-r it has been running badly (sputtering off the line and missing during acceleration) so I took it to get the codes checked to see if there was anything new and it said that there was an automatic transmission sensor bad, I have a manual transmission so I was wondering if anyone else has had this problem?
Sounds like your car came as an automatic. What were the code numbers?
I don't know I had advance check it and the car has always been manual I did have to swap the ECU out with a junk yard one after shorting something and frying the original one but the number were all the same between the two.
Then you got an automatic ECU.
is there any way to tell from looking at the ECU itself because I checked all of the numbers between the two ECUs and they were all the same with exception of the four digit one on the bottom right of the sticker on the ECU?
