1 - 13 of 13 Posts
Alright this is driving me crazy...I'm doing a swap right now and last thing I need to do is remove the axle nuts. I'm cranking on it enough that the engine is cranking and it is in 1st gear too! Question is what can I do to stop that... or could i do Plan B- I remove the engine w/o taking the tranny out..since I'm not doing anything to the tranny...could it be done?
if you dont have an impact/cant afford it, go and get a 3/4" x 4' iron pipe (like $5 at HD), slip it over your ratchet, you'll have no problem then, i've used mine many times breaking things loose, including those axle nuts, before my friend started storing his air compressor in my garage.
hah, sorry guys i must be erally tired because 5 minutes after i asked that question it dawned on me that I need the car on the ground, lol.. no wonder my torque wrench wasn't doing anything.... thanks guys...
SE-R Mana
Not a good use for a Torque wrench. Really, use a impact wrench or breaker bar. If you don't have a breaker bar, buy one. It's cheaper than having to replace your torque wrench after you unknowingly change it torque properties. Hell, even a wratchet and socket combination would be better. Good luck.
lol, first time ever doing something like this, I broke my torque wrench, never did find the spring.
got it broke loose, cool, its all down hill from here.
On Vacation
Just put a flat head in the middle/opening section of the rotor (the flathead will come to the caliper which won't allow for the rotor to spin anymore) and take a strong hollow bar (for leverage) and put it on the rachet and loosen. Works like a charm.
Manny
Veritas
Or, wedge a crowbar between one of the wheelstuds and the top hat of the brake rotor. Rotate rotor until the crowbar hits the ground, and wedges the rotor/hub from moving. Apply torque. Off it comes.
Charlie Brown look alike
I personally use an professional Ingersoll-Rand 1/2" impact. :) Works like a charm. The easiest thing to do is lower it on the ground and let the weight if the car do the work for you. Don't feel too bad because I did the samething awhile back.
1 - 13 of 13 Posts
