High comp lowport
Does anyone know for a fact that the SE-R came with power windows as an option? or if the gxe or nx switches fit the b13 door panels? i just put in the spal power window kit and the switches are really starting to bother me. i just cant get them to sit right so i want some oem ones.
www.FAIRTAX.org
The SE-R was never equipped with factory power windows. I don't thing the switches from the GXE or the NX would fit well. Serban used B14 switches when he did his 5ish years ago and they looked pretty good.
Do you have a pic of the spal switches?
Definitely use the B14 swtich, the b13 gxe won't fit, and even if it did, you'd have 2 extra switches. Same with the NX, won't really fit.
Here's the B14 one
You just need to cut the handle part, its too deep, and it hits the seatbelt in the door. I just glued a piece of flat plastic to cover the hole, made for a nice change tray :D
www.FAIRTAX.org
Silvia, I picked up an extra set of the B14 switch assemblies at the Junkyard this w/e. Let me know if you are interested in them.
