Progress B13 coilovers part # 75.1509:
Spring rates are 350/250 with the valving dyno tuned for those rates. Shortened strut bodies provide 1" more travel over stock. These are meant to utilize the OEM upper perches, however since the springs are 2.5" ID they should work fine using Ground Control tophats with the Ground Control caster/camber kit and Shigspeed rear pillowballs. Ride height is adjustable. Revavling of the struts is available for $49 each rebuilding for $69 each. Springs will be grpahite gray like their swaybars and the LCA brace are.
$1300 shipped
Progress B13 lower control arm brace part # 16.1509:
This is a three point brace that utilizes the OEM rear crossmember bolts as a center mounting location with adjustable spherical bearing endlinks and longer bolts for the lower control arm pivot mounting location. As soon as I know what sized downpipes will clear this brace I will post that information.
$160 shipped
How to order:
Due to the possible volume and dollar amount of this I am only accepting money orders and cashier's checks, made out to me, Rob Faber and mailed to 10408 Crown Point Ave. Omaha, NE 68134. PLEASE place your forum name and an e-mail address somewhere with your shipping information so I can keep in communication with you. Your order is placed as soon as payment is received and is shipped directly to you from Progress. As of this date, 10/24/04 the braces are available for shipping and the suspension should be as well within the next week. Please PM me if you have any questions or concerns. I will update this post with new pictures and information as soon as it is made available.
-Rob
$1300 shipped
$160 shipped
How to order:
-Rob
