1 - 20 of 62 Posts
"Beware the Classic"
Welcome to my project page! The purpose of this thread is to keep track of my progress, upgrades, and maintenance of my very first SE-R. Thank you for the comments and please feel free to put your honest input on anything that you feel needs attention.
Discussion Starter · #2 · (Edited)
02/28/09:
Hello to all forum viewers! As you may know, I just newly acquired this good condition sr20de powered SE-R classic. I've been a member on this forum since 2005, but I've been driving a 1.6L powered B13 for quite some time until now. In 2004, when I first got the car, I researched and found that there were 2.0L powered ones designated as the SE-R version. Since then, the SE-R has always been the "unicorn" since I could never find one around my area. So I set forth making my 1.6 look like an SE-R, taking guidance from this forum on how to make it look nice and tasteful. I proudly represented the B13 crowd, as I am still the only one in the city to customize this car nicely imho. With all the civics and integras around and 240 guys asking me why I drive this car, I don't hesitate to tell them it's about being different among the crowd. Well lo' and behold I finally found the unicorn I've always wanted. However, there are some certain flaws that come with a used car that I cannot live with, and therefore, I must proceed to "modifying" :tongue: . I will be documenting the things I do to it in this thread throughout the length of my ownership of the car to keep track of the work I've done. Wish me luck! :biggthump
Purchased the car from Darel (9d1ser) for $2500 with some extra parts 2/25/2009:
http://www.sr20forum.com/cars-sale/245199-92-b13-sentra-se-r-sacramento-ca.html
Next to my old B13 LE
Starting the project:
02/26/2009
Replaced front door speakers (both sides) with aftermarket Pep Boys brand
Removed rear speakers (replace later)
Attempted repair of headliner with 3M adhesive spray (not so good)
02/27/2009
Clean out interior
Removed cracked dash (this was a big PITA!)
anyone know what this is?
Degreased the engine bay (Spectre cone filter installed)
Painted stock exhaust muffler
Red L.E.D bulbs installed for instrument cluster
Photoshoot break...my Ying and my Yang :)
Discussion Starter · #4 · (Edited)
3/7/09
Front wheel bearings replaced (both sides), Starter Kit Replaced, Black 4-2-1 Header (2.5" downpipe) Installed, Removed Headliner, Used Headliner from Pick-N-Pull sprayed with black vinyl paint, Interior parts (i.e. B-pillars and oh-sh*t handles) painted semi-gloss black, installed aftermarket shift knob
Custom Short Ram Intake Installed (Place Racing Tube Design) along with 4-2-1 Header
3/9/09
Used Front Dash picked up from a 94 B13 Sentra at Pick-N-Pull sprayed with semi-gloss black engine enamel. This took the longest time to remove/install since it caused me some electrical problems with the friggin cluster!! Had to make sure speedo and all the cluster was working before fully tightening the screws :squint: . I also transferred the VIN from the old dash to the new dash : (p.s. I ended up with a bunch of extra screws and not everything hooking up perfectly...climate control panel isn't out all the way with the rest and center vent is kind of stuck and hooked onto the dash and separated from the actual center piece; *All these issues are now fixed as of now :))
Oh yeah it works just fine (fuel guage works along with both speedometer and tachometer :))
3/13 to 3/15 2009
The new parts to be put on have arrived :):
2.5" Custom Mandrel Bend exhaust (2 45 degrees and 2 90 degrees), 20" length 2.5" in/out resonator, 2.5" OBX/Forza dual tip muffler
I also painted the rear turn signals red with transparent paint
I'm currently waiting on the arrival of the 2nd generation road magnets so I can put these Drag dr21's on
Trying out the hood bra (nah...)
I fixed the corner light a bit to close the gap and installed the 626 lip. It's amazing how this little addition actually makes the car look much better
VR3 Speakers were ghetto fabricated due to my lack in cutting skills
Photoshoot break...my 2 B13s chilling on a nice day
UPDATE!! Addition upgrades as of March 20, 2009!
Got the windows tinted - 5% rear and 35% for the driver and passenger windows
New front windshield with blue tint installed
Discussion Starter · #6 · (Edited)
Nice, Your sentra looks a lot like my old white se-r. Nice work
Thanks ulysses, compliments mean a lot. It's def a lot of hard work and long hours so far, but fun at the same time. Everything that I'm trying to do to this car is definitely from forum related material and reading a bunch of other B13 threads so I'm gonna make mine look good in the end. It won't be the "typical" classic on B14 wheels, but will definitely be unique and tasteful. It's a money pit too lol...Nice sig quote btw;) . And about that friend who told me I should have bought an S13 instead...I showed him the meaning of the SE-R the other day:biggthump
Dude nice work! I was wondering how hard is it to take that dash out?:biggthump
O-Rod, let's just say that I hated the whole process LOL. Removing it seemed to take forever since there were so many bolts. I suggest removing the two big ones above the dash first (where the tabs are near the windshield vents) Then go from right to left with glove box, center console, unscrew things UNDER center console from ash tray to your sound unit or deck, electrical tabs, under steering wheel covers, cluster overlay with electrical tabs, and then cluster (did not remove the speedo cable from tranny, after taking out the electrical tabs, I sort of yanked on the cluster and out came the speedometer pin sensor pin from the rear), then two final nuts holding two bottom ends of dash. Driving for 2 weeks with NO DASH until I found a gray one with small cracks was pretty annoying, but kinda cool, but hella ghetto at the same time haha. After painting it, at least putting it back together seemed easier, sorta...all in all it was a nice experience I'll never forget. All that just to change 2 little burnt out bulbs to 3 red ones lol
supersaloon
:rofl: That post you had made about the s13 instead, made me laugh so much, it had to be my sig. I like what you did with the tail lights. I was wondering what kind of paint you bought,and where did you buy it. $$? ? Where did you get that rear strut bar? looks really nice. What color are you going to paint the car if you are painting it again? Anyways good work. I like hows this is going. Keep it updated with lots of pictures. Should come down to so-cal :biggthump
Well for the lights i used Testors Transparent Hot Rod Red since they had no candy apple red. I think it looks more lighter than the candy apple redso it actually matched the tails compared to my other sentra where I used candy apple. Also sprayed it with a high gloss clear coat also by Testors. I got it from some hobby shop store where they sell model cars.
The rear strut bar came with the car when I bought it. I don't know the brand to tell you the truth. And for the paint I'll probably go with a darker red, not maroon and not aztec, but something like Honda red...I don't know yet.
Original Owner
Nice work! Sweet post.
Proud Italian
Good work. I like the dual tips myself
Discussion Starter · #14 · (Edited)
UPDATE again as of March 24, 2009
Maaco Presidential Paintjob (Fire Red) They were having some limited 50% off on the paintjob
I wasn't there to see the car arrive home as I'm still in Sacramento, but my sister texted me some pics. I'll take some better pics this weekend and show you guys the new paintjob. A little more to go...installation of the Road Magnets, wheels, and alignment and she'll be to my liking (student loan money pit....but it's worth it!)
Prior to paint, i removed all side markers and told them not to paint the side mirrors, grill, or the 626 lip
Discussion Starter · #15 · (Edited)
Fresh Paint as of 3/26/2009
More parts to go...we have to install the road magnets, get an oil change (5w30 full synthetic), change to 300zx fuel filter, and get an alignment with the new wheels and she'll be finished...for now
Discussion Starter · #17 ·
Discussion Starter · #20 · (Edited)
man Im loving the new paint, how much you paid for that??
450 total with prep work (sanding/primer) + clear coat. They have a sale on paint until march 28th 200 dollars off! :biggthump
So she's finally done...FINALLY!!!
New updates as of 3/28/09
Rear seats re-installed, Road Magnet Springs on OEM struts installed, changed to Castrol Syntec 5w-30 w/ K&N oil filter (switched to synthetic at 151,250 miles), 300ZX Twin Turbo fuel filter, 300ZX leather shift knob installed, 4 lug universal DRAG DR21 Silver w/ polished lip wrapped in 205/50/R15 Hankook Ventus tires installed, Thrust Alignment from McCoy Tires (front wheels only)
Painting the springs
What they look like with the OEM wheels
Getting wheels mounted and alignment from McCoy Tire
The "ALL DONE" photos :)
Some more dress-up stuff as of 4/21/09
Replica Nismo engine oil cap, radiator cap (1.3 kg/cm), Nismo tire valve caps (hope they don't get stolen lol) and Nismo emblem
Some vids of the car
1 - 20 of 62 Posts
