1 - 20 of 21 Posts
SHIFT_ SuCka
http://i20.photobucket.com/albums/b235/greense-rious/i-8_T.jpg
http://i20.photobucket.com/albums/b235/greense-rious/82_12_sb.jpg
http://i20.photobucket.com/albums/b235/greense-rious/f3_12_sb.jpg
let me know what yall think, deff got plans for it already have K&N airintake, short shifter on the way ( one thing I dont like is the factory shiftknob replacing it with lower knob), headers and i replaced the factory 95 driver gauges with 98 model they are white hopefully this spring turn my sr20de to sr20de(T) :) .....but over all car not bad for 2,100 adult own nice older fellow from MA he pamperdd it and change the dirty oil when needed :rofl: .......feedback and ideas for it thankkkkks
SHIFT_ SuCka
Im located in Easthartford, thanks for the feedback, yeah I waited all summer looking for one and finally came across a nice deal. I am planning on going all motor with it only exterior I plan to do is buy 17'' rimz but nothing over 17LB's;) other then that no changes. Im hereing alot of forum memebers talk about these s4 intake cams that can let you rev higher with the g20 ECU, I would like to get that in and shift around 7400-7500 and then save up for juice:cool:
Carving Corners
Get a g20 ecu and 91-91 intake cam. You could probably score both for around $150 and together they will make a noticable difference.
SHIFT_ SuCka
Discussion Starter · #11 ·
Thats a good idea I didnt think about using classic cams. cuz s4's brand new are llike 500+, now for the ecu, whats the difference between the G20 and Jim wolf tech ecu?:confused:
Blast From The Past...
The difference between the two ECU's is mainly cost but, there are advantage's to using the JWT ECU too many to name(you might just want to run a search on it).
I for one use a 95 G20 ECU and with it I was able to raise my rev limit too 7500 and have no speed govenor. When I had added my 91' Intake Cam and 95'G20 ECU, it made a world of difference being able to rev higher and having a little more kick with the cam. Two very good and well worth the price mods IMHO...
Big Cheddar fan club
I just go the identical car added to my collection. I am in the process of repainting it now. I think I am putting in a Hotshot gen5, s4 cams, popcharger, 2.5" exhaust and of course ........ the bottle. You gotta keep your baby fed;) . I think I may also do GC's with AGX's not sure on the setup I want to do yet. Nice car man, hope to see it.
SHIFT_ SuCka
Discussion Starter · #14 ·
Im looking at headers to buy this is noobie question cuz I am a noobie, I looked at hotshot headers which range from like $400- 500, DC sports but bad reveiws and OBX which are around $200 mid range headers prolly not the best but alright, with just intake bolt on how much of a difference in low and top end speed would the hotshot have over the obx do you think?? cuz im tight on cash but dont want to buy a very expensive namebrand header if its only puttin up tiny bit more numbers then a header thats almost half price
Yeah, I got the '91 intake cam and a G20 ecu, and you can def. tell the difference with just those mods. Other than that, I'd just save up for a VE swap, all-motor champion right thurr! =]
sr20speed said:
Listen to featherweight13, All motor is the sh*t.
pshhhhh....
if you dont wanna go as fast as you COULD go with turbo.....;)
1 - 20 of 21 Posts
