ok so I got my bar from Toolapcfan (thanks!!) and finally had a chance to install it yesterday. The instructions were easy to understand and had decent pictures for the mechanically inexperienced (like me). The install goes well, it's quite easy - 4 brackets, 2 on each side attach to the rear trailing arms and the bar attaches to the brackets.
One word of warning, the instructions say to loosen the brake cable (a new spacer is provided so that it works with the brackets), but no mension of the abs sensor wire. How I know this is because I start my car and the abs light comes on, yup the the inner most brackets cut into the abs wire - so I had to undo the bar and fix both abs wires then put the bar back on.
For those of you who have the progress rear bar - did any of you run into this issue? Also when torquing to 30lbs (per the instructions) my C-shapped brackets started bending. And to top it all off my passenger side inner bracket (towards the front) hits my 3" exhaust. Any ideas/comments welcome.
