Can anyone help me figure out these wiring harness. I bought mine from centerstage group at a groupbuycenter.com. I don't know which one of the wires is the ground, hight beam, low beam. If anyone can help me that would be great. The colors are green, brown, white. Thanks.
Bryan
hey I have some instructions on how to install them in my yahoo briefcase. Just go to http://briefcase.yahoo.com/domiguy and download the documents... there are 2 I think, one is a word document, and one is a powerpoint... the powerpoint has some pictures and the color codes
I actually fixed the problem just by looking at the harness. I looked at where the wires are coming from and I ended up with this conclusion; The green one is the ground, the gray and brown are either high beams or low beams. Just hook it up and if they are switched , you can tell coz it is just gonna be on high beams. just switch them back. GREEN is definitely ground. The OEM ones: the black is ground and the red/black is HIgh beam.
UMM, just look at the directions that I have, it's in there, and the directions will REALLY help you install them... by the way, you will also need 4 nuts, they need to fit into the two holes on the side of each projector headlamp... but I really suggest you look at the instructions I have, they will probably help you out, especially the one with pictures
