I am using Wilwood 4 piston calipers. I actually just finished the install with the help of the boys. I ended up using a 5mm spacer. I am going to order some longer wheel studs next week somtime. I do not feel to safe running the OEM studs. They seem a little short.Are you going to be using the AD22's w/ the kit or the wilwood 4piston calipers?
I would definitely NOT do any aggressive driving if you are using the stock wheel studs. I am running the Forged Dynalites with Coleman Racing 2-piece 11" rotors (aluminum hat) under my B14 "SE-L" rims using H&R 5mm spacers which came with longer wheel studs.I am using Wilwood 4 piston calipers. I actually just finished the install with the help of the boys. I ended up using a 5mm spacer. I am going to order some longer wheel studs next week somtime. I do not feel to safe running the OEM studs. They seem a little short.
Thanks for the replies guys. I honestly was under the impression that the rims would fit without a spacer. Man even with the spacer in place it is a tight fit.
that looks hot... but don't you need air in that tire??
Cheers-
Erich
-saaby
Cool deal man.
I really do not feel to safe using the OEM wheel studs. Longer studs will be ordered soon.
You should just give me the brakes then, I've already got longer studs...![]()
Worst case, take them off and I can give you a hand when you get here.By chance does anyone have a detailed write up or pictures of how to properly install these? I usually figure sh*t out for myself but, as many of you know I am moving to Ohio and I leave in a few days. Time is very limited and I have alot of other thinsg to worry about.
Let me know how it goes. I've got a question out to my racer contacts about bleeding the calipers too.I am going to give it one more shot tonight. My boy Lance has a set of Wilwoods on his B13 so I am going to compare and make sure I am doing this right.
If not when I get to Ohio I will mess around with it a little more and will take you up on your offer. Geekout! and Blair's place!! :biggthump
