when i installed my S4 cams it says 50-100 mile break in, under 3.5grand.there is no break in period like the JWT cams?
Of course there is... or there should be at least !there is no break in period like the JWT cams?
can i have some money for a dyno please.haha.
Im thinking maybe 150whp.
Ive got 4 pc pullies and those cams, what should i set the timing at?
i Concur... i also use zylene for good mixture with 93*set the timing at 19* and use 93 octane. Makes a healthy difference.
19deg is tried and True. Some people will tell you 19deg's and some will say 17deg's. Its all about where your car like its timing advanced to.what is the stock timing? how did u go about deciding 19 degrees. ( not being a assh0le, just wanna learn timing)
If you advance your timing you have to run higher octane fuel.So is it necessary to advance the timing?
Would I be able to leave it at 15-17 degs?
I just don't want to have to use the 93 grade octane .
Gas prices these days are outrageous! I think were almost up to $3.80 a gallon here in Hawaii! I'm content with the hi-port intake cam upgrade, but these are too dirt cheap to pass up.
