1 - 8 of 8 Posts
Boost Gets You Laid!
well its been over a year and a half since my 200 has been running, im just wondering if theres anything i should do before trying to fire it up again, mainly with the engine,turbo,Fuel system. any input would be appreciated ! thanks
spark plugs , oil change , coolent flush , things like that could help also fuel dont start it with old fuel that could suck up gunk into the motor
i replaced the spark plugs rite before she went down, should i still replace them?
im going to do an oil/filter change, drain the old gas, check my plugs, the coolant is going to be new b/c of the new rad, maybe the brake fluid, any other ideas?
Drivin' my life away. . .
I suggest pulling the fuel pump fuse, taking out the plugs and spinning the engine with the starter until the oil pressure builds up. That way you will have oil in the turbo and top end before you fire it up.
1 - 8 of 8 Posts
