I am assuming this is for your power source? I actually did it to the wire coming from the radio that turbs it on when you turn on the car, really simple, unless yours is factory then you could do what Brian said. You could also run a power wires to the fuse box, or if it is for the illumination of the gauges, tap into your hazard switch. If you need to know what wire on the hazard switch, Ill have to look at lunch!
