Hows it done? I got Powerstop x-drilled rotors and Axxiss metal matrix pads for the front. I was told you have to bleed the brakes after the install.
Jordan White (Stormy)
'98 SE(R) w/ HS CAI, HS G3 Header, JWT s4 Cams, UR Pulleys, KYB AGX's, Eibach Sportlines, Courtesy STB's, ES Mounts, ES Bushings, PWST X-Drilled Rotors w/ Axxis MM Pads, 17" Borbet Type S's w/ 205/40 Kumhos, Nis-Knacks goodies
'98 VR6, stock (the womans car)
