Ok Ok On going problem with my boost controller, even though I dont have my car with me at the time, this problem has been dwelling on my mind. Anywhoo Im still not sure if I hooked my BC up correctly because right now I have it set on AC actuator, when I have an external wastegate. I have the Tial 35mm wastegate with one line running off the side to the unit, I also have another line which is the boost source running right off the first pipe off the compressor side, When I have it like that it boost 8- pounds with the unit off, when I turn it on it jumps to ten without moving the Dial, If I set the box to WG or Wastegate the boost isnt registered it will just clime to as much as it wants I guess cause once I saw it hit 16 lbs I let off quicker then cat in a fire. So what do you think is the problem, When I turn up the boost dial sometimes it increases and sometimes it doesn't , Im starting to get confused, anyone with this unit that has gotten it to work please help me out.
TIA,
Mike.
Turbo Classic, t3/T04e Tial 35mm Custom piping griffen intercooler, custom manifold, 370cc injectors, paxton fpr, Super AFC Apexi, Greddy EGT, AM Boost, HKS Turbo Timer, Blitz SBC, Eibach Sportlines , Haltec coming soon, full facelift coming soon.
TIA,
Mike.
