1 - 2 of 2 Posts
Ok guys it seems thay my rear brakes get stuck when i put my hand brake upafter done driving then drive it again.It seems only the pass side rear is getting stuck.I change the calipers on both sides, brake pads. ANd they still get stuck. Any help? bakes lines? hand brake cable?
Richie
get some wd40 spray and a brush and clean the back of wheel area by the caliper and e brake line assembly.get the little springs especially then coat the little e brake springs with white lithium grease spray to protect from future road dirt and grime. worked for me and you can do this from under the car without taking the wheel off.
1 - 2 of 2 Posts
