I have a 91 G20. I have to replace my brake pads and turn the rotors pretty soon. What is the best (OEM like) aftermarket brake pads should I use? Is Brendix Import Quiet pads any good?
Nelson
"What is a G20 stands for?" G-spot 20x.........
· JordanWhiteMusic.com
Never heard of those. If you want a OEM-like pad, why not just get OEM pads in the first place? Also, the Axxis Metal Matrix are pretty good. I have them and I'm happy. They were like $40 a pair or so.
Stormy
'98 SE w/ HS CAI, HS G3 Header, Custom 2.25" Exhaust, JWT S4 Cams, UR Pulleys, KYB AGX's, Eibach Spings, Courtesy F&R STB's, ES Mounts, ES control arm bushings & shifter bushing (NI), Brembo X-Drilled Rotors w/ Axxis MM Pads, 205/50 Pirelli's, Nis-Knacks goodies....in need of a JWT ECU
www.WhiteLineRacing.com
· SNAIL SQUAD
I also have Axxis break pads. They were definently a good purchase! My car stops so much better.
RED 92 CLASSIC- NOS,H/S HEADER,INTAKE, EXHAUST, MSD IGNITION, ACT CLUTCJ AND PRESSURE PLATE!
· employment whiplash, NC
All those pads are good. Even the OE pads are pretty decent. IMO, the BEST pad I have ever used for street are Porterfield R4-S. Pricey? You bet. Try ~$70 for just the fronts. Worth it? Damn straight they're worth it!
Matt
92 SE-R from Heck
