ok this sucks, I get brake squeal from 20-40 mph while accelerating... it comes and goes, but it usually happens when the brakes are warmed up. If I step on the brake pedal the sound will go away, but as soon as I let off, the sound comes back (or until I go slower than 20mph/faster than 40mph). I think I've determined the sound to be coming from the front brakes, although the squeal is so loud that I can't be too sure...
I didn't grease up the front metal retainer things that sit on the top/bottom of the caliper when installing my new pads and rotors (I only greased the rear up), nor did I lube up the pin bolts (I think that's what they're called)--the bolts that are taken out to open the caliper upward. I also didn't put any grease/compound behind the brake pads.
Any recommendations on what I should do? btw my pads/rotors are a mere 2 weeks old (oem replacement rotors/axxis ultimate pads)
Sounds like your into the wear indicators , the pads have little metal tabs that rub on the rotors causing a squeel , that tells you to go to a shop so they can tell you you need new brake pads !!
actually I have new pads all around, they're only 2 weeks old...! Anyway I adjusted the parking brake and lubed up the front calipers/bolts, even put a thin layer on the back of the pads. I still get squealing while accelerating... forgot to mention that I also get squeal while braking when they're cold.
I think the sound is actually coming from the rear right brakes. I'll try removing the rear seats and see if it actually is.
I remember nicking the rear right pads when installing them: I had a hard time slipping the caliper onto the rotors, and I ended up putting a groove on the outer pad while trying to force it on the caliper... I think that could be my problem. Well I've yet to lube the rear brakes so I'll see if that'll get rid of the squeal.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
SR20 Forum
