were you cranking in the correct order, torque and had the cam seated properly with the bearing caps in the correct direction and original position?
i havent had problems but if you accidentally put them in the wrong place, over torque, or flip the bearings the wrong direction, you can mess up the bearings cam and bolts.
hope you didnt sheer them off below the surface, then u must extract them, had to do that on 2 motor mount bolts on my old car, wasnt bad tho.
good luck, just be extra careful on those cam installs.
