1 - 2 of 2 Posts
Ok, i went through the trouble of replacing my tranny case due to it being cracked from the mount bolts busting through their holes, only to realize that the part on the frame where the mount bolts up to has a small crack, and the correct bolt hole is all worn and loose. The jackass that had the car before me just drilled up another hole (I think) and put the mount bolt through there. By doing this the bracket doesnt bolt up. Basically my problem is that the mount can't correctly bolt up to the frame. This is a salvage title car, so the frame damage isn't surprising. What can be done for it? If my description is too confusing I can get some pics of it. :biggthump
1 - 2 of 2 Posts
