Yeah, I know it looks scary. The spindles are forged and are more prone to just deform than break. Under normal conditions there isn't all that much load on the tie rods to steer the car. When the car gets hit is when you need to worry. It has been hit hard enough to take it out of a race, and it just twisted the steering arm on the upright maybe 5-10 degrees, but didn't break anything. In hindsight, if we had enough spare tires in the hot pits to get the car back out there, we would have just eyeballed the toe back straight and run the rest of the race. We thought we were done so we didn't bother. I guess my point is that in a hard impact, there is plenty of other stuff that can and will fail on any car. On other cars I've seen tie rod failures (the joints), failed balljoints, broken or bent struts, brake rotors separate from hats, failed control arm links, etc. from similar impacts. I feel like the level of risk is no greater than any other component of the suspension/steering system for that type of crash. Any of those will end a race or cause a big accident. One example is last year at Atlanta - Bob Endicott had a minor crunch and kept going. Coming down the hill either a brake or tie rod gave up from the previous impact and he entered the hot pits at speed and went into the wall.
I totally acknowledge that it looks bad from an engineering standpoint. The other option would be to raise the rack, but it would cause a lot of other problems and interference. One other thing to note is that this car is REALLY slammed. Most of the time the spacer would be much shorter.. On the Proteges, there is no spacer - we mount the tie rods on the bottom and adjust bumpsteer with the (small) spacer on the lower balljoint. 6 one, half-dozen the other I guess.
The roundy-round guys have been doing this type of thing for a long time, though I don't know if their uprights are better suited to accept twisting loads on the steering arm. Well I guess not
I just looked at Coleman, and their generic kit uses the same size bolt (5/8) and is supposed to be for stock Pinto spindles! They use a stack of skinny steel spacer bushings to fine tune bump steer. Not trying to say "well if circle track guys do it, it must be safe!" , just trying to add another data point.
andris
