O.K what's up X honduh owner. the color you want is a light tan to chocolate brown plug with no eroded or melted parts on the plug. Platinums are good if you drive like an old man but in an se-r it won't happen. get NGK brk6e or bkr6e plugs and gap them at .032 and you'll be on the money. the gap clearance is from .031-.035 so even .031 is good as they will wear on you in time. standard plugs are cheap too like 1.50 each. compared to plats 4$ and up each. I know some will say other wise but I have never used plats and have had no problems but do have to change them often every 15,000 or less due to honduh whippin' mostly and racin'.
