Guest
·How much did you get it for and from where?
Yeah, but i mean, i heard about having to take out fans and watever to get it up there, and i just figured itd be easier if he told me what i had to take apart, before i actually went to do it. know what i mean<font face="Verdana, Arial" size="2">Originally posted by ser_200sx:
You dont have to do it all by yourself. I will come up and help you.![]()
399 plus shipping, from Louis(APEXSER) at APEX motorsports in Arizona. Well i didnt actually talk to Luois, he wasnt in yet, but i talked to Andy, who is also a greta guy<font face="Verdana, Arial" size="2">Originally posted by twentyfivecharacters:
How much did you get it for and from where?</font>
Sweet.. I guess I can take a lil drive to tempe and get one when I find some money. Andy has a nice car. Supra TT I believe.<font face="Verdana, Arial" size="2">Originally posted by RPWSER:
399 plus shipping, from Louis(APEXSER) at APEX motorsports in Arizona. Well i didnt actually talk to Luois, he wasnt in yet, but i talked to Andy, who is also a greta guy![]()
It's been a looong time since I put mine on but IIRC you have to remove the fans, cross member, and I removed the AC hose that's in the way but someone else said they were able to loosen the compressor bolts enough to squeeze the primary by the hose.<font face="Verdana, Arial" size="2">Originally posted by RPWSER:
Jay, just got the AEBS header, should be here in the next 2 days. I was wondering if you or anyone you knew has a write up on the install. Im doin it myself no matter what, and just tryin to make it as easy as possible. Or if you have any hints or suggestions that you could just lemme know. TIA.
That was me, I installed mine about a month ago. Some notes. Get the car good and high on a set of<font face="Verdana, Arial" size="2">Originally posted by Jay Hass:
Good point on the mounts...that's what I ended up doing too.<font face="Verdana, Arial" size="2">Originally posted by Soupaflie:
jackstands. As you are removing misc. items keep
dousing the header bolts with liquid wrench. the airconditioning lines do
not need to be removed. there are 4 bolts that hold
the compressor to the engine block. Just back out
those 4 bolts and hold the compressor out of the way
to slide the header past. Some items that needed
removed: radiator fans, oil catch can, front engine
mount, lower crossmember, and EGR tube. The install is
not as difficult as most people think. I installed the
header and reinstalled my courtesy exhaust all in less
than 5hrs. Including repairing threads on a stud my
brother destroyed and plenty of goofing around. If you
plan to install the ES motormounts ever, do it at the
same time.
Here are a couple of installed pics I took. I meant to do a install write-up with pics but got in to much of a hurry.<font face="Verdana, Arial" size="2">Originally posted by twentyfivecharacters:
Are you able to post any pictures of the header? If anyone has pictures, post them too, please.</font>
If you look close you can see a dent in one of the tubes. I did that the day after installing it on a huge ice chunk in the middle of the road. But, to answer your ? no I haven't scrapped it on the ground yet.<font face="Verdana, Arial" size="2">Originally posted by twentyfivecharacters:
WOW.. that looks nice. Do you ever scrape?</font>
