OK I am going to clean up this post for clarity.
If you want to make things easy on yourself when putting cams back in the motor, ensure the Crank is at TDC by checking the position of the #1 cylinder piston with a long screwdriver/thin metal rod, and looking at the crank pulley. Don't mistake the very first mark for TDC or 0*. It goes (for a B14, 98 specifically):
-5........0..........5..........10...13...15........20
you want it at 0. If its not at zero, it will be tough to install cams as you work against the valve springs. It gets a lot easier at TDC (the cam probably wont fall right in, don't force it cuz you're just compressing valve springs and not accomplishing anything, just torque it down, using fingers at first, veeeeery carefully. Then check for the cam being able to rotate around.
About tools, for cam swaps you will need both a 1" and 1-1/16" wrench. Sometimes the cam hex lines up for one wrench, sometimes for the other, or it felt like one cam would use one wrench, while the other was different. I dunno, but get both. Also, make sure the wrenches aren't too wide, I ran into this problem and it sucks. Try them out on the cam hex if you can.
Deep well 10 and 12mm sockets are fun to have, but a 2" extension or whatever can make up for it.
27mm socket for turning the crank.
24mm shallow socket for the cam sprocket bolts. Otherwise, you wont't be able to fit around the coolant hose or the power steering resevoir.
Get a light if you plan to work into the night.
A bendy socket wrench or a bendy open wrench helps for the timing chain tensioner, or stuff in general.
Patience is the best tool to have. If that doesn't work, I guess you can always get a sawzall...
OK, onto the problem now. The cam timing is off. I need to get it perfect again. Hopefully I can do this without taking the front cover off, essentially requiring dropping the motor, but if it comes to that, o well.
Here's a recap of the key points:
- tensioner out
- cam sprockets off cams
- cam swapped, first at -5*, then really at TDC
- sprockets fell into motor at some point, thought i skipped a tooth on the crank sprocket (apparently impossible)
- rotated crank around until TDC reached, chain links in an unknown position
- exhaust cam dowel set to 12:00, intake set to 10:00 (cam lobes point out)
- chain laid back on sprockets, seemed a bit off, sprockets both moved one roller clockwise to line up the dowel pins even more at 10 and 12.
- torqued cam sprockets back on
- confirmed TDC w/ radio antenna in place of screwdriver
- installed tensioner
- when I rotate the crank to about 40* CW or CCW, I can't rotate the crank anymore. Hypothesis: valves are hitting pistons.
Current plans of action:
(evilsr20degg)
- take sprockets and cams out
- rotate chain again until the silver/black colored-marked-mating links are about in the relative right position (up top by mating marks for sprockets, around 10 and 12 I guess) when the crank is at TDC.
- put sprockets on chain, hang them up.
- install cams, bolt on sprockets
- test again by rotating the crank
- if it rotates fully, check to make sure the cams return to the same position every 2 revolutions of the crank
(worst case scenario)
- Take off front cover. Line up chain by hand.
Do this either by the FSM instructions, leaving the engine in the car, or by dropping the engine out.
- tensioner out
(evilsr20degg)
