/// God Speed! ///
nx2000racer said:
I remember reading a while back that 94+ had larger oil squirters for the cams?
is this true and is it worth swapping in?
I don't believe the updated tube is needed unless it keeps getting clogged up.
If I had a reason to pull the VC off I would check it. You will be able to tell if
one of the squirters are clogged, the cam lobe will look scored.
AWD owns me
just put that baby at least once a day to 7500 and they won't ever clog up
JordanWhiteMusic.com
If you are concerned about your tubes being clogged, just remove them and spray some carb cleaner through them. I don't believe the 94+ tubes are significantly larger to justify shelling out the money for replacements, they are most likely somewhat pricey.
Bitter Old Man
There is indeed an updated part with larger holes, I believe it started on G20s. Don't know the year they started, but if you buy new ones that's what you'll get.
