I have a technical question for you guys that can offer a detailed explanation. I recently installed a set of s4 cams into my 95 se-r. Before the install my distibutor was in the middle to get 15 degrees, after the install it has to be pushed all the way forward to get it to go to 15 degrees. How can I fix this?
1. Verified top dead center with a long screwdriver.(second mark from left)
2. Intake cam at 10 and exhaust cam at 12
3. 20 rollers between marks on cam gears
4. Car runs good pulls hard above 5000 rpms
5. verified that timing is reading correctly with scanner ( done at autoshop after I paid them 260 to fix , but they did not)
Now I have read almost every post related to this subject but none seem to give enough information. From previous posts it sounds like I am retarded one tooth on the crank or about 13 degrees. This would seem simple to fix but if everything is lined up perfectly the way it is, how in the world would there be a way to remedy this. Now if I did assume I was retarded one tooth on the crank there would be more than one way to fix this. Advance both sprockets forward one tooth or to leave the sprockets stationary and move the chain one tooth toward the rear of the car which would require moving crank counter clockwise to provide enough slack in the chain. I have tried both ways and what happens is that I end of overadvanced ( distributor needs to be almost fully retarded to read 15 degrees. Either way that I go it is too advanced or too retarded. The cams will only line up correctly one way and when this is accomplished I always end up with the distributor almost fully advanced. I have been fooling around with this for over a month now and my brain hurts. I was wondering if there is anybody that can shed light on the subject that can give tech details on what is actually going on.
Note. All the info that I have seen has stated that the distributor has to be in the middle for cam timing to be correct.
Sorry for long post but I wanted to be specific.
