Was installing my new Bolt-On Bars B14 Rear Strut Bar and came across something disturbing. I've noticed the center hole on the passenger side Motivational Mounts expanded across the mount. No wonder I hear the so-called rear suspension noise associated with these mounts. The strut nut is on tightly and securely on the AGX shocks. The shock itself has plenty of play and can't be tighten any more. I've already contact Motivational Engineering and aware them of this problem and hopefully something can be done.
So if anyone else is running these mounts, just do an inspection and see if you have the same problem I'm having.
Here's a pic of the expanding center hole. You can't really see how much it expaned but the center hole is an indication it's not sitting properly.
