Hi guys, Ok so I have just about finished rebuilding an SR20DE. No real problems until today when I was putting the camshafts back in. The manual says tighten camshaft bracket bolts in 3 steps.
1)tighten to 1.4 ft-lb
2) then tighten to 4.3 ft-lb
3)then all the way up to between 6.7-8.7 ft-lb
The problem is my first bolt didn't even make it to 4.3 ft-lb before I felt it snap. Not the end of the world, so I tried bolt two same result.I stopped here because I'm doing something wrong.
I got the broken ends of bolts out of the head, but need someone who has the answers to tell me what the issues are.
What is causing these bolts to fail?
They're not even making to half the required torque,and there are 22 of these suckers to tighten up.
Did I put the wrong lenght bolt in the wrong hole?.
If someone could tell me is it the shortest bolts on the inside row and the longer bolts on the outside row?.
I hope all this makes sense.
Thanks for your input.
