Does any one know if the JWT s-2 exhaust cam will work in combination with any other JWT intake cam like the s-3?. I broke the intake cam on my s-2's but was thinking about upgrading at least the inktake since i gotta buy a new one. Any advise or suggestions?
Andreas Miko i know u can answer this.
97 200sx se-r. [email protected],
with 100 shot JWT program. JWT s-2 cams. MSD 50lb injectors, cobra MAF, JWT fuel rail, ACT 6 puck clutch.
Jah Rastafari
you have no problems running S3 or S4 though I would go with the S3 because they would be more closely matched. If you have cam gears I would go with S4 because with the gears you could get the S2 to run alittle more like a s3. Better said you would be able to match them more closely
what will be the advantage of going with the s-4 if in the future i wanted to go turbo? where about should the s-3/s-2 combo pull at? same for the s-4. What is YOUR recipe for higher reving???
