Okay here is my situation. Im really leaning toward getting the HKS step 1 cams for my 96 nissan 200sx ser. However im a bit confused as to which ones to get because information seems contradictory in the forums. I'm assuming ill need the s13 cams but im not sure, are the s13 cams the correct application? Also, in regards to shortening the pin on the exhaust cam, how is this done? can that be done at home with a grinder or will a machine shop's help be neccessary?
you need to use s13 camshafts, and for the pin.. you pull out the pin from your factory cam, and switch it with the long one found in the hks exhaust cam. use some locktite, and tap it in with a hammer.
SR20DE stock G20 p10 highport
I believe LanceSR20 meant to say IF YOU USE THE s13 CAMSHAFTS, YOU WILL NEED TO USE THE STOCK OEM DOWEL PIN FROM YOUR FACTORY CAMS WITH THE NEW s13 CAMS.
