WASHED UP
??? also it that the best kind of wastegate
Hey man,
You *can* use a Tial wastegate with the F-MAX manifold. You just need to specify when you order your manifold which wastegate you will be using. F-MAX makes wastegates compatible with the following wastegates:
1. standard HKS
2. Turbonetics Deltagate
3. Tial
The Tial is the "best" and has awesome construction and uses very good materials, including inconel, which is very heat resistant.
The HKS is also a very nice piece as well and support plenty of hp.
I would stay away from the Deltagate due to poor quality and a high number of diaphragm failures reported after their use.
Go with the Tial or the HKS.
Jay Whitely
Tampa, FL
1996 200SX SE-R
GTi-R powered with F-MAX kit
where are your yellow spark plug wires yO?
j/k, very j/k
98 se-r w/ p/r cai,jwt s3 cams, stillen header, courtesy exhaust, ur pullies, JUN flywheel, ACT clutch, eibach springs, kyb struts, st sways, cusco camber plates, f/r strut braces,stillen lower control arm brace,SMC BAKB, motul 600 brake fluid, lotsa bushings, and a bunch of other crap
Off-Topic lurker..
that is freaking exquisite looking...
Aztec Red 1993 NX2000
