I got all my suspension stuff installed yesterday(except for the damn LCA bushings cause they still haven't comin yet) and when they aligned they couldn't get 2 degrees of camber out of it. So my car has two degrees on the left and stock spec on the the right!
Anyway, what could cause this to happen. I already have a camber correction kit on it from the Eibach install. When the Eibachs were put on the alignment was stock spec on both wheels.
96 w/ HS CAI, timing @ 17, 92 I/E cams, Naxos muffler, Eibach Sportlines, Front struts: Motivational, Rear shocks: KYB AGX's, S/T sway bars, ES lower control arm bushings and motor mounts, Courtesy F/R STB, APC Clear corners, Stillen grille, and Focus short throw.
