ok, i installed my "new" jspec engine and it runs fine...at least it does now, but anyways, i also installed an ACT 6 puck Xtreme pressure plate clutch. i cranked up my car, and tried to put it in first gear, and it wont go. when the car is off, i was able to put it in gear, so the clutch is not disengaging...ive checked my clutch cable, adjusted it, im not sure if i adjusted it right, but ive spent 2 days messing around with my clutch cable, and everything. has anyone had this problem, and what could be wrong?...help please!..i need my car!
Discussion Starter · #2 ·
humm...i think so, i mean, i tried the opposite way, and it was hard to insert into the the transmission shaft..so i fliped it and it fit right in...so i dont know if thats the problem...hope not, dont want to have to take out the transmissions again...
dude check my post on the act some time last month. same her back then and an easy fix is in the post.all my boys with act have done the same and worked.
El Chingon
Stupid question... Are you sure you put the disc on the right way? A disc that is backwards can cause the problems you're having....
David
'98 Super Black SE w/stuff
you don't need more than 2 washers about a 1/4" thick altogether. if you put too many you can stretch the cable. check thetranny and make sure it's on good all mounts are tight.
