I just wanted to share a tip with you guys on keeping theTB cleaner longer. I removed the hose that goes from the intake pipe to the valve cover breather and replaced the hose on the cover with a small k&n breather filter and covered the hole to the intake part with a rubber bypass cap about 2 bucks for 2 and 10 months later today went to clean the TB and it's clean as hell. It usually gets dirty I think cause theres oil in the valve cover and the intake will definitely suck small amounts in the TB giving you that black sludge. no lie this thing was clean. I usually clean it every 6 months but now who knows. works for stock intakes as well.
