Does anyone know if anyone sells clear front marker light assemblies?. I have already found side clear markers from nis-knacks but he didn't have the front one.
Discussion Starter · #2 ·
Just make them your self thats what I did. Get some plexiglass cut them out in the same size as the fronts but rectangular. I did it this way because I used a small hand saw, and I could not cut curves. The plexiglass would chunk into jaged shapes. Then I had a sanding disc on a drill and smooth the edges down till they were the same shape. then drill two holes for the screws. and take a fine grit sand paper and scuff the inside edge up to kinda diffuse the light some and its not see through clear. The OE lense pops off the base of the turn signal and there is a black rubber strip in there throw it away. It will fall out if you leave it. screew it down but not to tight or it can crack. Then BBBWWWWWAAAAAMMMMo instant clears(just add water)
