1 - 10 of 10 Posts
95NismoB14grl
Well has anyone with their turbo cars get a clogged or melted convertor??? How did you know? What are the signs?? I know the sign of lack of power but i think i may have a clooged converter. If i get no responses i guess i'll have to wait till wed to bring it to work and pull the converter down.
utahnissans.com
I melted the inside of my cat, it felt like therewas something holding my car back around 4-5K rpm. I dropped it out and it was bad. Hope this helps.
95NismoB14grl
yikes..well im noticing very high egt's!!!!! did yours go through the entire rpm range???
95NismoB14grl
so you guys are saying its most likely a melted convertor causing my high idle/WOT boosting egt's???
I guess this is something that I have to look forward to since I have a converter on my car now. Lucky I got a e-cutout!
Mr.200SX @ the dash
Do what I did.. I took it off and destroyed everything in it.. after I did that my car hits redline so much quicker. Right now my car is running a little rich so I was gonna kill it anyways so I got head of time before the car did. :)
95NismoB14grl
well guys i pulled the convertor down and found it was broken..i punched it out and went for a ride. Still runs hot. I saw 1550 deg F so i let off(mind you this is JUST getting to full 7PSI!!!!) it idles at 800deg F!!!! Its actually running a little bit hotter!!! WTF!
95NismoB14grl
Discussion Starter · #10 ·
alrighty...i wanna check that but i dont remember which line on the UR pulley i need for 15 deg.
1 - 10 of 10 Posts
