When I got to work this morning I noticed a clunking noise. I have a 48 mile commute and I did not notice anything until I was close to work. I drove to lunch and it was worse. Yesterday, I had the front end in the air for a couple hours. I started to replace the front brake pads, but I had the wwrong pads. This was my first time doing anything with brakes but I think I reinstalled the caliper correctly. I didn't take it off, just took out the bottom bolt and loosened the top and pivoted the caliper up. I torqued it to spec. I changed the oil and added some waterwetter. The car was in the air without wheels for a couple hours.
The clunking is rhythmic and is worst while coasting (constant speed in gear or in nuetral) and while shifting slowly. I do not think it is motor mount related. I think it is axle related but I don't know what to look at. I have the dogbone and (firewall transmission) rear insulator ES inserts. The car is a 99 Sentra SE. My parking lot inspection did not reveal any torn boots (the ones closest to the the wheel). I could not inspect much farther. It is not an improperly installed rim.
I have to drive 65+ miles this afternoon to an exam. What should I look at and what would happen if I kept driving? I don't think I should keep driving, but I might need to.
Thanks,
Jason Schymanski
Thanks,
Jason Schymanski
