Ok, my car has 5th gear popout, so I am swapping the tranny from my old sr20 powered car. I have a ACT HD PP/Street disc combo that came out of the old car. From what i have read the disc is basically a stock nissan disc. The clutch assembly is about 6k old, the disc shows miimal wear however the springs are alitte loose. I was told buy a se-r veteran that I should replace the disc. I immediately think 2001 disc. So I have the following questions.
1) Should I replace the disc?
2) Would it be a big mistake to buy a autoparts store disc instead of dealership?
3) How many discs can I go throuh before the PP is needed to be replaced?
TIA
bump, for more opinions
Coropate greed hater
Well, not really. 6,000 miles of use isn't much, unless it was 6,000 of nothing but abuse. If you do replace it, getting an '00 SE disc is not a bad idea at all.
Yes. The discs/clutch kits that autoparts stores like Autozone, Advance Auto etc. carry are not meant for abuse.
Depends on the condition of the PP. If the fingers are gone to hell and the overall condition of the PP looks bad, it's time for a replacement. No one can guess how many dics it can take before the PP needs to be replaced. It's an item that has variable rate of wear, meaning some may need to replace it really early, some can go without replacing the PP for a long time. Therfore, YMMV.
SE-R Searcher
with only 6K miles the disc is probably fine. Also, you may have problems using a stock nissan disc with a ACT PP. I am not sure that the clearances are the same for the disc and PP surfaces.
