Leather Face
ok guys my mate has a u12 sr20det and i was doing taking off the gearbox and after doing the last mounting bolt the tranny fell off the block and pulled out the ignition transistor and coil wires with it, i found that the person who installed the fly wheel didnt torque it in properly and used the shorter auto bolts, anyways i hooked everything back up and found that there was no spark through all cylinders even installing spare coil, transistor and dissy cap, so my question is how many volts should i be seeing on the wires that go to the coil and transistor or what other tests can i perform to find the issue?
thanks
