I'm going mad!
I start my car and it starts fine and will idle without any problems. I can put it in drive and it will go forward until it bumps up into second gear.
At this point:
If I continue to accelerate, it's fine, but has a hard time accelerating well.
If I coast/brake to a stop, it will stall. If I restart at this point, it starts fine, but will stall immediately if I put it in drive or reverse. The problems aren't as bad now that it's warmer out, but it almost happened this morning at 45 degrees.
Once it is warm, it drives more or less fine, but seems to lack power, doesn't seem to shift where I would expect it to, and will drop down into first or second pretty hard if I jam on the gas.
Thanks.
At this point:
Thanks.
